Neato XV-21 Fan Replacement
  1. Neato XV-21 Fan Replacement, Back Panels of Neato XV-21: step 1, image 1 of 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Fan Replacement: step 2, image 1 of 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Fan Replacement: step 3, image 1 of 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Fan Replacement, Battery: step 4, image 1 of 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Fan Replacement, Fan: step 5, image 1 of 2 Neato XV-21 Fan Replacement, Fan: step 5, image 2 of 2
    • Pinch the white connectors to disconnect the fan from the robot, as previously done with the batteries
    • Once the wires are disconnected lift the fan from the cavity
  6. Neato XV-21 Fan Replacement: step 6, image 1 of 1
    • Once the fan has been removed you can take a damp cloth and clean the cavity before attaching the new device
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,131
