Nerf Dart Tag Furyfire Large Spring Replacement
  1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove the screws: step 1, image 1 of 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Panel: step 2, image 1 of 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Black Cylinder: step 3, image 1 of 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: step 4, image 1 of 2 Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: step 4, image 2 of 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
Bradley Penrow
37 Reputation
4 Guides authored
USF Tampa, Team 11-2, Blackwell Fall 2014 Member of USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,444
