Nerf Dart Tag Swarmfire Motor Spring Replacement
  1. Nerf Dart Tag Swarmfire Motor Spring Replacement, Motor Spring Replacement: step 1, image 1 of 2 Nerf Dart Tag Swarmfire Motor Spring Replacement, Motor Spring Replacement: step 1, image 2 of 2
    • Using the JIS #1 screwdriver, loosen the nine screws, holding the outer yellow shell in place
    • The screwdriver you'll be using is a J1 head from the 64 Bit Kit.
    • Be sure to sure to use the Magnetic Project Mat to prevent loss of the screws.
  2. Nerf Dart Tag Swarmfire Motor Spring Replacement: step 2, image 1 of 1
    • Lift off the outer yellow shell.
  3. Nerf Dart Tag Swarmfire Motor Spring Replacement: step 3, image 1 of 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: step 3, image 2 of 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: step 3, image 3 of 3
    • Remove the screw holding the battery compartment shut.
    • Lift off the inner blue casing
  4. Nerf Dart Tag Swarmfire Motor Spring Replacement: step 4, image 1 of 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: step 4, image 2 of 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: step 4, image 3 of 3
    • Lift off the blue casing, exposing the white motor spring compartment.
    • Loosen and remove the three screws holding the white compartment door shut.
  5. Nerf Dart Tag Swarmfire Motor Spring Replacement: step 5, image 1 of 2 Nerf Dart Tag Swarmfire Motor Spring Replacement: step 5, image 2 of 2
    • Unsnap the white compartment into two pieces.
  6. Nerf Dart Tag Swarmfire Motor Spring Replacement: step 6, image 1 of 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: step 6, image 2 of 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: step 6, image 3 of 3
    • Remove the motor spring located inside the rotating barrel and replace.
Sonal Purohit
115 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 876
