Nerf N-Strike Deploy CS-6 Dart Tooth Replacement
  1. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement, Dart Tooth: step 1, image 1 of 1
    • Before releasing the device in Stealth mode, take out hidden screws as shown
    • Extend the device in Stealth Mode by pressing the button found on the handle.
  2. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 2, image 1 of 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 2, image 2 of 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 2, image 3 of 3
    • Take out the screws from the pump.
    • Proceed to take out the other screws from the device to take off the cover.
    • For the pump, the screw's length extends out to 1.9 cm. The majority size of the screws extend out to 1.3 cm.
  3. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 3, image 1 of 2 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 3, image 2 of 2
    • Once the screws are out, you are able to take the cover piece off.
    • Proceed to remove the screws
    • Taking off those screws are vital in replacing the dart tooth.
  4. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 4, image 1 of 1
    • Carefully place cover piece above the device.
  5. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 5, image 1 of 1
    • Unscrew as shown to aid in the replacement.
  6. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 6, image 1 of 1
    • To take out the dart tooth, push the spring to the left.
    • The dart tooth should pop out with ease.
  7. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 7, image 1 of 1
    • Once pulled away from the device, take off the orange piece connected to the darth tooth
    • The piece can be identified with the spring.
  8. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 8, image 1 of 1
    • You should now be able to pull apart the dart tooth from the device.
    • The piece that has been pulled away will have a type of lubrication. If this piece requires replacement, it will slide on with ease.
  9. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 9, image 1 of 1
    • Make any adjustment to the dart tooth as seen. May be pulled either up or down.
    • Place in the replacing piece in order to fix the darth tooth
  10. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 10, image 1 of 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 10, image 2 of 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: step 10, image 3 of 3
    • Place back on the orange piece with the spring to its original spot on the dart tooth.
    • While setting in the dart tooth back into place, the small spring on the yellow piece must be placed in its compartment as shown.
    • Place back cover pieces in order to secure the screws back into place.
2 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 27
All Time: 2,982
