Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement
  1. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement, Light-bulb Lens: step 1, image 1 of 1
    • Proceed to take out the hidden screws when the device is collapsed.
    • Hidden screws measure out to 1.7 cm
  2. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 2, image 1 of 2 Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 2, image 2 of 2
    • Once the hidden screws are out, extend your device in stealth mode.
    • Once the device is extended out, proceed to take out the necessary screws as shown.
    • For the pump, the screw's length extends out to 1.9 cm. The majority size of the screws extend out to 1.3 cm.
  3. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 3, image 1 of 1
    • Once all the necessary screws are taken off, the interior of your device should be visible.
    • Unscrew the orange barrel located in front of your device.
  4. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 4, image 1 of 1
    • Now that the cover is off and the screws are out, pry off the barrel of the device.
  5. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 5, image 1 of 1
    • Once the orange barrel of the device has been pried off, proceed to take the metal clip off from where it is currently located.
  6. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 6, image 1 of 2 Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 6, image 2 of 2
    • As shown, use your Phillips #0 head screwdriver to unscrew the highlighted areas
  7. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 7, image 1 of 1
    • Once all the screws have been removed, the cover for the light-bulb is able to come off.
    • Gently remove the cover to maintain the safety of your device.
  8. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 8, image 1 of 1
    • When taking off the cover piece, gently place it above the device as shown.
    • Regarding the ligh-bulb cords, it should have a strip of tape to keep it down.
  9. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 9, image 1 of 1
    • Near the light-bulb is the lens. Gently pry it off.
    • Correctly dispose your damaged lens.
  10. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: step 10, image 1 of 1
    • Once you acquire your new lens, gently place it in front of the bulb.
    • As shown, the lens should be placed where the edges line up.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 831
