Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: step 1, image 1 of 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: step 1, image 2 of 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: step 1, image 3 of 3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: step 2, image 1 of 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: step 2, image 2 of 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: step 2, image 3 of 3
    • With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: step 3, image 1 of 2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: step 3, image 2 of 2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: step 4, image 1 of 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: step 4, image 2 of 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: step 4, image 3 of 3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, use a spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: step 5, image 1 of 2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: step 5, image 2 of 2
    • Remove the two 5mm phillips screws from the rifle muzzle.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: step 6, image 1 of 1
    • Remove the muzzle and barrel from the rifle body.
  7. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: step 7, image 1 of 1
    • Separate the muzzle from the barrel.
Elizabeth Coffey
404 Reputation
3 Guides authored
Cal Poly, Team 10-35, Maness Winter 2014 Member of Cal Poly, Team 10-35, Maness Winter 2014
CPSU-MANESS-W14S10G35
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 5,869
