Nerf N-Strike Elite Hail-Fire Battery Replacement
  1. Nerf N-Strike Elite Hail-Fire Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the two 9.0 mm Phillips screws from the battery compartment.
  2. Nerf N-Strike Elite Hail-Fire Battery Replacement: step 2, image 1 of 1
    • Pull the battery compartment out and away from the gun.
  3. Nerf N-Strike Elite Hail-Fire Battery Replacement: step 3, image 1 of 1
    • Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
  4. Nerf N-Strike Elite Hail-Fire Battery Replacement: step 4, image 1 of 1
    • Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
  5. Nerf N-Strike Elite Hail-Fire Battery Replacement: step 5, image 1 of 1
    • When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
6 other people completed this guide.
Jonathan Peck
217 Reputation
1 Guide authored
Cal Poly, Team 13-13, Regan Winter 2014 Member of Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 Members
7 Guides authored
One Comment
thanks it works
unturned lore - Reply
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 76
All Time: 25,908
