Nerf N-Strike Elite Retaliator Barrel Replacement
  1. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel: step 1, image 1 of 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Grip: step 2, image 1 of 1
    • Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
    • This may require more force than anticipated.
  3. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel Cap: step 3, image 1 of 1
    • Disassemble the orange barrel cap by removing two 8mm Phillips screws.
  4. Nerf N-Strike Elite Retaliator  Barrel Replacement, Disassemble Barrel Assembly: step 4, image 1 of 1
    • Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
    • There are springs that may become displaced when the barrel housing is removed. Proceed with caution.
  5. Nerf N-Strike Elite Retaliator  Barrel Replacement, Replace Barrel: step 5, image 1 of 1
    • Remove the orange barrel from the assembly.
6 other people completed this guide.
ericharman
1,410 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 40
All Time: 11,470
