Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement
  1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Case Disassembly: step 1, image 1 of 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: step 2, image 1 of 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: step 3, image 1 of 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: step 4, image 1 of 2 Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: step 4, image 2 of 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: step 5, image 1 of 2 Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: step 5, image 2 of 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Air Chamber: step 6, image 1 of 1
    • The firing spring may be energized. If so, carefully release and spring pressure before proceeding.
    • While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
  7. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: step 7, image 1 of 1
    • Slide the white air chamber forward and remove the white alignment bracket.
  8. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: step 8, image 1 of 1
    • Remove white air chamber by depressing the orange trigger apparatus and pulling backwards off of the barrel.
16 other people completed this guide.
ericharman
1,410 Reputation
5 Guides authored
4 Comments
Where did we found the pièces??
Albert Einstein - Reply
where i can buy for spare part “air chamber”?
sabeni83_king - Reply
this tutorial helped A LOT
Daniel MacDonald - Reply
OK I've removed the air chamber now what?
camper234 - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 48
All Time: 20,074
