Nerf N-Strike Elite Retaliator Trigger Spring Replacement
  1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Case Disassembly: step 1, image 1 of 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: step 2, image 1 of 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: step 3, image 1 of 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: step 4, image 1 of 2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: step 4, image 2 of 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: step 5, image 1 of 2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: step 5, image 2 of 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: step 6, image 1 of 3 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: step 6, image 2 of 3 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: step 6, image 3 of 3
    • Carefully pull the orange trigger upward and backward to remove it from the blaster.
    • This component is under spring pressure. Wear appropriate personal protective equipment to shield your eyes.
    • Remove the spring from the rear of the trigger.
ericharman
1,410 Reputation
5 Guides authored
One Comment
ok, taken the spring out. now what?
Kelvin Mead - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 9,374
