Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement
  1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: step 1, image 1 of 2 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: step 1, image 2 of 2
    • Remove three screws with a Phillips #1 screwdriver.
    • Remove the pump grip.
  2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 2, image 1 of 1
    • Remove thirteen highlighted screws using a Phillips #1 screwdriver.
    • The top rail has shorter screws than the rest.
    • Some of these are captive screws and cannot be removed.
  3. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 3, image 1 of 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 3, image 2 of 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 3, image 3 of 3
    • Remove the backside by sliding the plastic spudger across the seam.
    • There are loose parts that can fall out. Take these off and put them aside.
  4. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 4, image 1 of 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 4, image 2 of 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 4, image 3 of 3
    • Separate the trigger mechanism from the barrel.
  5. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 5, image 1 of 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 5, image 2 of 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 5, image 3 of 3
    • Remove the plunger springs from the mechanism by pulling one of the springs back then bending it off the connection.
    • These are tricky to remove, so be careful when pulling them off.
  6. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 6, image 1 of 2 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: step 6, image 2 of 2
    • Now pull the springs out and add new ones.
    • There are a few pieces with springs that can misalign in reassembly. Keep in mind where they are.
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 3,012
