Nerf N-Strike Elite Strongarm Unloading Button Replacement
  1. Nerf N-Strike Elite Strongarm Unloading Button Replacement, Outer Shell: step 1, image 1 of 2 Nerf N-Strike Elite Strongarm Unloading Button Replacement, Outer Shell: step 1, image 2 of 2
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 2, image 1 of 2 Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 2, image 2 of 2
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 3, image 1 of 1
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 4, image 1 of 1
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 5, image 1 of 1
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
  6. Nerf N-Strike Elite Strongarm Unloading Button Replacement, Unloading Button: step 6, image 1 of 3 Nerf N-Strike Elite Strongarm Unloading Button Replacement, Unloading Button: step 6, image 2 of 3 Nerf N-Strike Elite Strongarm Unloading Button Replacement, Unloading Button: step 6, image 3 of 3
    • Look inside the top cover of the blaster and locate the tab extending from the unloading button. It shouldn't be too hard to find as pictured since it will be the only orange piece.
    • Inspect the button's location for signs of debris impeding its operation. Replace if necessary.
    • Ensure the unloading button has a 45 degree angle contact surface.
  7. Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 7, image 1 of 2 Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 7, image 2 of 2
    • To make the relevant pieces accessible, remove the barrel from its position on the bottom half of the blaster cover.
  8. Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 8, image 1 of 2 Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 8, image 2 of 2
    • On the bottom half of the blaster, ensure the tab from the button makes contact with the barrel assembly.
    • Clear out any debris in the way, or replace the button as necessary.
  9. Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 9, image 1 of 3 Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 9, image 2 of 3 Nerf N-Strike Elite Strongarm Unloading Button Replacement: step 9, image 3 of 3
    • Reassemble and test the unloading button's functionality. The button should correctly lock and release the blaster's dart barrel!
2 other people completed this guide.
Alexander Kim
862 Reputation
3 Guides authored
USF Tampa, Team 5-4, Blackwell Fall 2015 Member of USF Tampa, Team 5-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G4
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 9,456
