Nerf N-Strike Firestrike Battery Replacement
  1. Nerf N-Strike Firestrike Battery Replacement, Remove battery cover: step 1, image 1 of 1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
    This should be step 1
    Samuel Garcia - Reply
  2. Nerf N-Strike Firestrike Battery Replacement: step 2, image 1 of 2 Nerf N-Strike Firestrike Battery Replacement: step 2, image 2 of 2
    • Slide out the two AAA batteries using your fingers.
    This should be step 2
4 other people completed this guide.
Hayes Kimball
742 Reputation
5 Guides authored
Cal Poly, Team 15-6, Amido Spring 2015 Member of Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Members
8 Guides authored
4 Comments
loved it it is amazing :)
arun patel - Reply
amazing loved it : )
arun patel - Reply
Do we rlly need alkaline batteries
Zikko Harmony - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 42
All Time: 10,840
