Nerf N-Strike Firestrike O-Ring and Plunger Replacement
  1. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, Remove battery cover: step 1, image 1 of 1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: step 2, image 1 of 2 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: step 2, image 2 of 2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, Blaster Casing: step 3, image 1 of 1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: step 4, image 1 of 2 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: step 4, image 2 of 2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: step 5, image 1 of 2 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: step 5, image 2 of 2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: step 6, image 1 of 3 Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: step 6, image 2 of 3 Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: step 6, image 3 of 3
    • Without removing the barrel assembly, tilt it slightly upwards.
    • Slide the plunger out from the air chamber.
3 other people completed this guide.
Clovis Jahan
200 Reputation
1 Guide authored
Cal Poly, Team 15-6, Amido Spring 2015 Member of Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 38
All Time: 4,750
