Nerf Surgefire trigger replacement
  1. Nerf Surgefire trigger replacement, Unscrewing the outer shell: step 1, image 1 of 2 Nerf Surgefire trigger replacement, Unscrewing the outer shell: step 1, image 2 of 2
    • Unscrew all screws in the blue and gray area.
    • Remove the blue and gray part.
  2. Nerf Surgefire trigger replacement, Unscrewing the inner shell: step 2, image 1 of 2 Nerf Surgefire trigger replacement, Unscrewing the inner shell: step 2, image 2 of 2
    • Unscrew all 3 screws holding down the white trigger cover (the trigger guard may be a different color).
    • Remove the trigger cover.
    • This image shows a Surgefire in working condition.
  3. Nerf Surgefire trigger replacement, Replacing the trigger: step 3, image 1 of 3 Nerf Surgefire trigger replacement, Replacing the trigger: step 3, image 2 of 3 Nerf Surgefire trigger replacement, Replacing the trigger: step 3, image 3 of 3
    • Here you can see how it looks when the trigger won't operate:
    • An "intermediate piece" is not in the right place or has fallen off.
    • Place the "intermediate piece" in the correct position (see photo 2).
    • Do not be surprised if the "intermediate piece" slides up a little. It is pressed down when the trigger guard is screwed back on.
    • In picture 3, you can see what it looks like when the part is in the correct place.
    • To reassemble your device, follow these instructions in reverse order.
Follow the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Lennart
169 Reputation
1 Guide authored
1 Guide Comment
Priming Handle Assembly , each part with springs pls explain
Sai Rakesh - Reply Share
Past 24 Hours: 7
Past 7 Days: 17
Past 30 Days: 73
All Time: 6,575
