Introduction
If any part of the handle or outer casing is damaged, disassembling the blaster may be required to repair it. A screwdriver with a long shaft will be needed to get to all of the screws. Also watch out for any small parts that may come apart and fall out as you're working on the device.
Start by taking out all of the screws for the casing of the gun. Using the PH #00 screwdriver, unscrew all four 1.3 cm screws in the pump.
Almost done!
