Nerf Vortex Praxis Trigger Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Nerf Vortex Praxis Trigger Replacement, Trigger: step 1, image 1 of 1
    • Start by taking out all of the screws for the casing of the gun. Using the PH #00 screwdriver, unscrew all four 1.3-cm screws in the pump.
  2. Nerf Vortex Praxis Trigger Replacement: step 2, image 1 of 1
    • Take out all of the screws with a Phillips screwdriver. Using a PH #00 Screwdriver, unscrew all fourteen, 1.2 cm screws.
  3. Nerf Vortex Praxis Trigger Replacement: step 3, image 1 of 1
    • Remove the small stock at the back end of the gun by removing two, 1 cm screws.
  4. Nerf Vortex Praxis Trigger Replacement: step 4, image 1 of 1
    • Pull apart the case of the gun by pulling up.
  5. Nerf Vortex Praxis Trigger Replacement: step 5, image 1 of 2 Nerf Vortex Praxis Trigger Replacement: step 5, image 2 of 2
    • Remove the trigger components by removing these two, 1.2 cm screws.
  6. Nerf Vortex Praxis Trigger Replacement: step 6, image 1 of 1
    • Pick up the pieces to the trigger assembly for replacement.
Diego medina
558 Reputation
5 Guides authored
IUPUI, Team 3-1, Harley Spring 2016 Member of IUPUI, Team 3-1, Harley Spring 2016
IUPUI-HARLEY-S16S3G1
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 618
