Nerf Zombie Strike Crossbow Cocking Mechanism Replacement
  1. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement, Cocking Mechanism: step 1, image 1 of 1
    • There are 19 1.0 cm screws.
  2. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: step 2, image 1 of 1
    • The cocking device air to be built up inside the Nerf crossbow, which generates the force needed to propel the darts.
  3. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: step 3, image 1 of 1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: step 4, image 1 of 1
    • Separate each part of the Nerf crossbow.
  5. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: step 5, image 1 of 1
    • Make sure the cocking mechanism is properly aligned with the rest of the Nerf crossbow.
  6. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: step 6, image 1 of 1
    • The cocking device needs to be attached to the plunger in order to function properly.
Benjamin Bucklin
61 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 3,496
