Nerf Zombie Strike Crossbow Plunger Replacement
  1. Nerf Zombie Strike Crossbow Plunger Replacement, Plunger: step 1, image 1 of 1
    • There are 19 1.0 cm screws.
  2. Nerf Zombie Strike Crossbow Plunger Replacement: step 2, image 1 of 1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  3. Nerf Zombie Strike Crossbow Plunger Replacement: step 3, image 1 of 1
    • Separate each part of the Nerf crossbow.
  4. Nerf Zombie Strike Crossbow Plunger Replacement, Removing the Plunger for Inspection: step 4, image 1 of 1
    • Carefully remove the plunger from the chamber for inspection.
  5. Nerf Zombie Strike Crossbow Plunger Replacement: step 5, image 1 of 1
    • Check to make sure the plunger is intact and has the the rubber stopper at the end of it.
    • Also make sure the spring is intact and is not bent.
    • If the spring is bent you can purchase one similar to it at a local hardware store.
  6. Nerf Zombie Strike Crossbow Plunger Replacement: step 6, image 1 of 1
    • Make sure that plunger is reattached to the cocking mechanism.
  7. Nerf Zombie Strike Crossbow Plunger Replacement: step 7, image 1 of 1
    • Check chamber to make sure that there are no holes or cracks.
    • If there are holes or crakes then the problem will not be able to be resolved since Nerf does not sell these types of parts.
Benjamin Bucklin
61 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 2,373
