Nerf Zombie Strike Crossbow Trigger Spring Replacement
  1. Nerf Zombie Strike Crossbow Trigger Spring Replacement, Trigger Spring: step 1, image 1 of 1
    • There are 19 1.0 cm screws in total.
  2. Nerf Zombie Strike Crossbow Trigger Spring Replacement: step 2, image 1 of 1
    • Separate each part of the Nerf crossbow.
  3. Nerf Zombie Strike Crossbow Trigger Spring Replacement: step 3, image 1 of 1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Trigger Spring Replacement: step 4, image 1 of 1
    • Take the broken spring off of the trigger.
  5. Nerf Zombie Strike Crossbow Trigger Spring Replacement: step 5, image 1 of 1
    • Replace it with the new spring you bought at your local hardware store.
  6. Nerf Zombie Strike Crossbow Trigger Spring Replacement: step 6, image 1 of 1
    • Now that the spring has been reattached to the trigger repeat step two.
    • Finish by performing steps two and three in reverse order.
Benjamin Bucklin
61 Reputation
3 Guides authored
One Comment
how do you get the arms/wings off without damaging the lock on clip?
Coventeena - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 3,617
