Introduction
If your Nest Cam IQ camera has lost clear viability, you most likely have a cracked camera lens, which Requires replacement.
A functional camera provides a clear view. If you notice poor camera quality or lines when pulling up Nest Cam IQ recordings, consider changing out your camera.
To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
Leave the iOpener on the glass lens for two minutes.
