Nest Cam Side Snap Locks Replacement
  1. Nest Cam Side Snap Locks Replacement, Side Snap Locks: step 1, image 1 of 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Side Snap Locks Replacement: step 2, image 1 of 3 Nest Cam Side Snap Locks Replacement: step 2, image 2 of 3 Nest Cam Side Snap Locks Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Side Snap Locks Replacement: step 3, image 1 of 3 Nest Cam Side Snap Locks Replacement: step 3, image 2 of 3 Nest Cam Side Snap Locks Replacement: step 3, image 3 of 3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Side Snap Locks Replacement: step 4, image 1 of 2 Nest Cam Side Snap Locks Replacement: step 4, image 2 of 2
    • Remove the four 3 mm Phillips #J000 screws from the side snap locks. Remove the old side snap locks and place the new side snap locks.
    • Make sure everything lines up for the screws.
Lisa Langley
207 Reputation
1 Guide authored
USF Tampa, Team 1-1, Leahy Spring 2016 Member of USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,009
