Nest Cam Speaker Replacement
  1. Nest Cam Speaker Replacement, Speaker: step 1, image 1 of 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Speaker Replacement: step 2, image 1 of 1
    • Open the back panel completely to expose the speaker indicated by the red circle.
  3. Nest Cam Speaker Replacement: step 3, image 1 of 3 Nest Cam Speaker Replacement: step 3, image 2 of 3 Nest Cam Speaker Replacement: step 3, image 3 of 3
    • Remove old speaker gently with a spudger.
    • When placing the new speaker in make sure the prongs are facing the right direction and will connect with the two connector points on the motherboard.
Jade Weiss
662 Reputation
3 Guides authored
USF Tampa, Team 1-1, Leahy Spring 2016 Member of USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Members
10 Guides authored
4 Comments
where can I buy the new replacement speaker part?
Bradley Kang - Reply
Anyone find out the answer to Bradley's question?
Ravi - Reply
I’m curious as well if anyone has found where to obtain replacement/repair parts. Should be simple enough if we can determine the part number of the speaker.. suppose I’ll tear one down real quick to see.
Christopher Monge - Reply
Looking at the speaker without thermal coverings looks like it just has some sound information. “8 ohm 0.5 w”. Next line, “1742 (space) 1”. Third line, “+ S -”.
Looks like electrical info of the speaker. I’ll keep looking!
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 2,712
