Nest Cam Wi-Fi Cable Replacement
  1. Nest Cam Wi-Fi Cable Replacement, Wi-Fi Cable: step 1, image 1 of 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Wi-Fi Cable Replacement: step 2, image 1 of 3 Nest Cam Wi-Fi Cable Replacement: step 2, image 2 of 3 Nest Cam Wi-Fi Cable Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Wi-Fi Cable Replacement: step 3, image 1 of 3 Nest Cam Wi-Fi Cable Replacement: step 3, image 2 of 3 Nest Cam Wi-Fi Cable Replacement: step 3, image 3 of 3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Wi-Fi Cable Replacement: step 4, image 1 of 1
    • Using a soldering iron, melt away the base of the Wi-Fi cable until it can be removed. Use this guild for assistance with soldering.
    • Ensure when you solder the new cable back on that all connector ends are positioned correctly.
Jade Weiss
662 Reputation
3 Guides authored
USF Tampa, Team 1-1, Leahy Spring 2016 Member of USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Members
10 Guides authored
2 Comments
I have broken the cable attached to Nest camera. Can you get replacement or repair the lead? Hope i haven't got to buy a new camera
Kerrie Davies - Reply
I have broken lead attached to Nest camera. Can i get a replacement or repair it? Hope i havent got to buy a new camera.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 26
All Time: 4,342
