Nest Dropcam Pro Camera Lens Replacement
  1. Nest Dropcam Pro Camera Lens Replacement, Outer Case: step 1, image 1 of 1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Camera Lens Replacement: step 2, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 2, image 2 of 2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Camera Lens Replacement: step 3, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 3, image 2 of 2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Camera Lens Replacement, Motherboard: step 4, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement, Motherboard: step 4, image 2 of 2
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Camera Lens Replacement: step 5, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 5, image 2 of 2
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Camera Lens Replacement: step 6, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 6, image 2 of 2
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Camera Lens Replacement: step 7, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 7, image 2 of 2
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Camera Lens Replacement, Camera Lens: step 8, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement, Camera Lens: step 8, image 2 of 2
  9. Nest Dropcam Pro Camera Lens Replacement: step 9, image 1 of 3 Nest Dropcam Pro Camera Lens Replacement: step 9, image 2 of 3 Nest Dropcam Pro Camera Lens Replacement: step 9, image 3 of 3
    • Peel off the paper seal holding the Lens and LEDs together.
    • Disconnect the red and white wire from the bottom board.
  10. Nest Dropcam Pro Camera Lens Replacement: step 10, image 1 of 2 Nest Dropcam Pro Camera Lens Replacement: step 10, image 2 of 2
    • Lift up the foam cover to reveal a second screw underneath.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws.
  11. Nest Dropcam Pro Camera Lens Replacement: step 11, image 1 of 1
    • With the screws gone, lift the camera lens away from the remaining components.
2 other people completed this guide.
David Foens
896 Reputation
6 Guides authored
USF Tampa, Team 15-4, Blackwell Fall 2015 Member of USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Members
12 Guides authored
2 Guide Comments
Where do you get replacement lens?
Jim Fischer - Reply
good morning , is there any store on the USA where i can send my drop camera ti get fix? it fell and doesn't want to broadcast any image.
andres - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 37
All Time: 4,071
