Nest Dropcam Pro Mounting Clips Replacement
  1. Nest Dropcam Pro Mounting Clips Replacement, Outer Case: step 1, image 1 of 1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Mounting Clips Replacement: step 2, image 1 of 2 Nest Dropcam Pro Mounting Clips Replacement: step 2, image 2 of 2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Mounting Clips Replacement: step 3, image 1 of 2 Nest Dropcam Pro Mounting Clips Replacement: step 3, image 2 of 2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Mounting Clips Replacement, Mounting Clips: step 4, image 1 of 2 Nest Dropcam Pro Mounting Clips Replacement, Mounting Clips: step 4, image 2 of 2
    • Using a Philips #0 screwdriver, remove the four 4 mm screws that are attaching the mounting clips to the case.
  5. Nest Dropcam Pro Mounting Clips Replacement: step 5, image 1 of 1
    • Lift the mounting clips away from the case.
David Foens
896 Reputation
6 Guides authored
USF Tampa, Team 15-4, Blackwell Fall 2015 Member of USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,401
