Nest Learning Thermostat 2nd Generation LCD Screen Replacement
  1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Removal from Wall: step 1, image 1 of 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Removal from Wall: step 1, image 2 of 2
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  2. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Open Display: step 2, image 1 of 1
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
  3. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove the back of the display: step 3, image 1 of 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove the back of the display: step 3, image 2 of 2
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
  4. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: step 4, image 1 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: step 4, image 2 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: step 4, image 3 of 3
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
  5. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Lift battery from the base: step 5, image 1 of 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Lift battery from the base: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
  6. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the battery from the motherboard: step 6, image 1 of 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the battery from the motherboard: step 6, image 2 of 2
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  7. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: step 7, image 1 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: step 7, image 2 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: step 7, image 3 of 3
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
  8. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Locate auto-away sensor: step 8, image 1 of 1
    • Locate the auto-away sensor.
  9. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screws: step 9, image 1 of 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screws: step 9, image 2 of 2
    • Remove the four 3mm screws with a #0 Phillips screwdriver.
    • Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
  10. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: step 10, image 1 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: step 10, image 2 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: step 10, image 3 of 3
    Buy
    • Lift the auto-away sensor from motherboard using tweezers.
    • Peel the copper foil gently from the EMI shield.
  11. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screw from motherboard: step 11, image 1 of 1
    • Remove one 4 mm screw from the motherboard using a #0 Phillips screwdriver.
  12. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove EMI shield from motherboard: step 12, image 1 of 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove EMI shield from motherboard: step 12, image 2 of 2
    • Remove the EMI shield from the motherboard using the plastic opening tools.
  13. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the LCD ribbon from the motherboard: step 13, image 1 of 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the LCD ribbon from the motherboard: step 13, image 2 of 2
    Buy
    • Unsnap the LCD ribbon from the motherboard gently using the tweezers.
  14. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: step 14, image 1 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: step 14, image 2 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: step 14, image 3 of 3
    • Locate the black tabs that hold the display to the motherboard.
    • Push the black tabs gently away from the motherboard using the plastic opening tools.
  15. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove from motherboard: step 15, image 1 of 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove from motherboard: step 15, image 2 of 2
    • Pull the face display gently away from the motherboard.
  16. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: step 16, image 1 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: step 16, image 2 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: step 16, image 3 of 3
    • The front of the glass display and plastic frame is held together by only light adhesive.
    • Push the crescent shape bottom of the display away from the plastic frame using the plastic opening tools.
  17. Nest Learning Thermostat 2nd Generation LCD Screen Replacement: step 17, image 1 of 1
    • Pry the front glass and plastic frame apart gently using the plastic opening tools.
  18. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove LCD screen from plastic frame: step 18, image 1 of 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove LCD screen from plastic frame: step 18, image 2 of 2
    • Pry the LCD screen gently from the plastic frame using the plastic opening tools.
  19. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: step 19, image 1 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: step 19, image 2 of 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: step 19, image 3 of 3
    • Pull the LCD screen away from the plastic frame gently using your fingers.
8 other people completed this guide.
Justin Curry
264 Reputation
2 Guides authored
USF Tampa, Team 11-5, Blackwell Fall 2014 Member of USF Tampa, Team 11-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G5
5 Members
12 Guides authored
5 Comments
Please could you say the type of LCD screen? Or present detailed photo of rear side?
vladvys - Reply
Yes, this is a guide for replacing the LCD. I'd like to know what LCD to order. Thanks.
kylegoetz - Reply
Thank you for providing this tutorial. My dog, not making this up, knocked my nest off the wall. Where can I purchase the replacement green itself and the plastic opening tools you used throughout the repair? This will be my first time on something like this, but with your guide I should have a decent shot at not screwing it up.
erick.starke - Reply
Skip step 12. There is no reason to remove the EMI shield.
richardrobison - Reply
Where can you get the replacement lcd screen for gen 2 nest learning thermostat?
Stan Griff - Reply
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 76
All Time: 15,268
