Nest x Yale Lock Keypad Replacement
  1. Nest x Yale Lock Keypad Replacement, Keypad: step 1, image 1 of 1
    • Unscrew all available screws that you can see from the back.
    • The screws are 0.25 inches phillips screws.
    • Make sure to not lose any of the screws, and keep track of them.
  2. Nest x Yale Lock Keypad Replacement: step 2, image 1 of 1
    • Once you have unscrewed all the screws carefully remove the metal covering.
    • Make sure that the wire safely goes through the hole.
  3. Nest x Yale Lock Keypad Replacement: step 3, image 1 of 1
    • Then once again unscrew the two screws that you see.
    • The screws have a height of 0.2 inches phillips screws.
  4. Nest x Yale Lock Keypad Replacement: step 4, image 1 of 2 Nest x Yale Lock Keypad Replacement: step 4, image 2 of 2
    • Once all screws are unscrewed proceed to tap the screen out of the metal casing.
Christopher Gonzalez
313 Reputation
3 Guides authored
One Comment
Where do you order the touchscreen from?
Mike Turrell - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 10
All Time: 357
