Nest x Yale Lock Keypad Replacement
Christopher Gonzalez
Christopher Gonzalez and 3 other contributors
Last updated on December 27, 2022
20 minutes
Moderate
Introduction
Go to step 1
If your Nest x Yale lock is related to any of the issues on the unresponsive section of your troubleshooting page, you may need to replace the touchpad. Use this guide to replace the keypad properly.
The touchpad is located inside the keypad. This touchpad is responsible for being able to input your code to unlock the door lock.
Before beginning this process, be sure that the device is off and not plugged into the lock.
  1. Nest x Yale Lock Keypad Replacement, Keypad: step 1, image 1 of 1
    • Unscrew all available screws that you can see from the back.
    • The screws are 0.25 inches phillips screws.
    • Make sure to not lose any of the screws, and keep track of them.
    I would suggest removing the word 'you' and start with 'Unscrew'
    Hazem Shekfa - Reply
  2. Nest x Yale Lock Keypad Replacement: step 2, image 1 of 1
    • Once you have unscrewed all the screws carefully remove the metal covering.
    • Make sure that the wire safely goes through the hole.
    No need to say 'also' since it is a note
  3. Nest x Yale Lock Keypad Replacement: step 3, image 1 of 1
    • Then once again unscrew the two screws that you see.
    • The screws have a height of 0.2 inches phillips screws.
    Provide an amount of how many screws needed to be unscrewed in this step
  4. Nest x Yale Lock Keypad Replacement: step 4, image 1 of 2 Nest x Yale Lock Keypad Replacement: step 4, image 2 of 2
    • Once all screws are unscrewed proceed to tap the screen out of the metal casing.
    The two photos in this step look very identical
313 Reputation
3 Guides authored
One Comment
Where do you order the touchscreen from?
Mike Turrell - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 10
All Time: 357
