Netgear Arlo 2 Camera HD Security System Camera/Lens Replacement
  1. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Case: step 1, image 1 of 3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Case: step 1, image 2 of 3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Case: step 1, image 3 of 3
    • Unscrew the two 3.0 mm Phillips #00 screws on the bottom of the camera.
    • Open the battery compartment on the bottom by pushing the switch marked in orange to the side and pushing the bottom of the camera back, sliding it open.
  2. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 2, image 1 of 2 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 2, image 2 of 2
    • Remove the bottom piece of the case over the battery compartment by placing a plastic opening tool underneath the edge of the case and prying it up.
    • Unscrew the four 3.0 mm Phillips #00 screws on the outside of the battery pocket.
  3. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 3, image 1 of 2 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 3, image 2 of 2
    • When facing the camera lens, the left panel of the case will be removed first (more steps are needed for the right panel).
    • Place the plastic opening tool between the two pieces of the case and pry them apart from the bottom.
    • Gently pull the side of the case off as it comes loose.
  4. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 4, image 1 of 2 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 4, image 2 of 2
    • Unscrew the smaller 3.0 mm Phillips #00 screw in the center on the back of the device.
    • Flip the camera over and unscrew the center 3.0 mm Phillips #00 screw above the SYNC button.
  5. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 5, image 1 of 2 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 5, image 2 of 2
    • Using the plastic opening tool, gently pry the right panel from the device.
    • Replace either side of the plastic case as needed.
  6. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Camera/Lens: step 6, image 1 of 3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Camera/Lens: step 6, image 2 of 3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Camera/Lens: step 6, image 3 of 3
    • Unscrew the four 4.0 mm Phillips #00 screws on either side of the transparent case.
    • Separate the transparent half of the case from the white half.
    • Only separate the two halves enough for them to be apart. The flat ribbon cable is short and its connection is delicate.
  7. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 7, image 1 of 2 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 7, image 2 of 2
    • Lift the small thin black rectangular latch that covers the connectors of the flat ribbon cable.
    • The latch is very flat, so use a finger nail or a spudger to lift it. Do not use any sharp edge like a knife as it will likely damage the device!
    • With the latch lifted, the cable will pull away freely as you separate the white half from the transparent half.
  8. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 8, image 1 of 3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 8, image 2 of 3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 8, image 3 of 3
    • Repeat the same process as in Step 6 to release the flat ribbon cable from the black rectangular latch
    • Unscrew the six black 3.0 mm Phillips #00 screws that hold the black motherboard on.
    • Release the clip at the bottom left corner of the black motherboard by pinching the wings at either side of the clip.
    • Be sure that the transparent case or the black motherboard are being held or resting on a surface so that neither falls when the clip is released.
  9. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 9, image 1 of 3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 9, image 2 of 3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: step 9, image 3 of 3
    • Remove the black plastic that contains the camera from its place.
    • Discard and replace this part as needed.
Ben Ingleson
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,709
