Netgear WGR614v9 Capacitor Replacement
  1. Netgear WGR614v9 Capacitor Replacement, Lower Case: step 1, image 1 of 1
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Capacitor Replacement: step 2, image 1 of 2 Netgear WGR614v9 Capacitor Replacement: step 2, image 2 of 2
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Capacitor Replacement: step 3, image 1 of 2 Netgear WGR614v9 Capacitor Replacement: step 3, image 2 of 2
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Capacitor Replacement: step 4, image 1 of 1
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Capacitor Replacement, Motherboard: step 5, image 1 of 1
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Capacitor Replacement: step 6, image 1 of 2 Netgear WGR614v9 Capacitor Replacement: step 6, image 2 of 2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. Netgear WGR614v9 Capacitor Replacement, Capacitor: step 7, image 1 of 2 Netgear WGR614v9 Capacitor Replacement, Capacitor: step 7, image 2 of 2
    • Rotate the motherboard so that the top is facing up.
    • Set the motherboard on a flat clean surface.
  8. Netgear WGR614v9 Capacitor Replacement: step 8, image 1 of 2 Netgear WGR614v9 Capacitor Replacement: step 8, image 2 of 2
    • The capacitor can be found at the location shown.
  9. Netgear WGR614v9 Capacitor Replacement: step 9, image 1 of 2 Netgear WGR614v9 Capacitor Replacement: step 9, image 2 of 2
    • Rotate the motherboard so that the bottom is facing up.
    • Locate the two soldered contacts of the capacitor.
  10. Netgear WGR614v9 Capacitor Replacement: step 10, image 1 of 3 Netgear WGR614v9 Capacitor Replacement: step 10, image 2 of 3 Netgear WGR614v9 Capacitor Replacement: step 10, image 3 of 3
    • Rotate the motherboard 180 degrees.
    • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
    • Refer to this link for proper de-soldering and soldering techniques.
    • Pull the capacitor from the other side of the circuit board once the solder is liquified.
    • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
Kyle Moore
95 Reputation
1 Guide authored
Cal Poly, Team 21-24, Maness Fall 2011 Member of Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Members
11 Guides authored
1 Guide Comment
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 47
All Time: 3,496
