Netgear WGR614v9 Lower Case Replacement
  1. Netgear WGR614v9 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Lower Case Replacement: step 2, image 1 of 2 Netgear WGR614v9 Lower Case Replacement: step 2, image 2 of 2
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Lower Case Replacement: step 3, image 1 of 2 Netgear WGR614v9 Lower Case Replacement: step 3, image 2 of 2
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Lower Case Replacement: step 4, image 1 of 1
    • Lift the bottom casing straight up from the router.
Ryan Murphy
488 Reputation
4 Guides authored
Cal Poly, Team 21-24, Maness Fall 2011 Member of Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,643
