NeuTab Air7 Battery Replacement
  1. NeuTab Air7 Battery Replacement, Back Cover: step 1, image 1 of 3 NeuTab Air7 Battery Replacement, Back Cover: step 1, image 2 of 3 NeuTab Air7 Battery Replacement, Back Cover: step 1, image 3 of 3
    • Ensure your device is powered off before you begin.
    • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
  2. NeuTab Air7 Battery Replacement, Battery: step 2, image 1 of 2 NeuTab Air7 Battery Replacement, Battery: step 2, image 2 of 2
    • The following instructions require soldering, which can risk burn injuries as well as component damage for those novice in the skill. Tread with caution.
    • For a guide on how to solder, click here.
    • Remove any adhesive tape that is holding the wires protruding from the battery down.
    • De-solder the red and black wire ends that connect the battery to the motherboard.
  3. NeuTab Air7 Battery Replacement: step 3, image 1 of 2 NeuTab Air7 Battery Replacement: step 3, image 2 of 2
    • Using metal tools can cause damage to the battery and potentially create a fire hazard. ESD safe tools are recommended for this operation.
    • Wedge a plastic or nylon spudger underneath the battery, moving it back and forth to separate it from the device.
    • Remove the battery.
Jason Soares
532 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 243
