NeuTab N7 Pro Battery Replacement
  1. NeuTab N7 Pro Battery Replacement, Battery: step 1, image 1 of 1
    • Power off your device before beginning disassembly.
    • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Battery Replacement: step 2, image 1 of 1
    • Follow the red and black wires from the battery to where they are soldered to the motherboard.
    • Warning: Use caution when handling a soldering iron to avoid injury or damage.
    • Use a soldering iron to separate the positive and negative wires from the motherboard.
    • For a complete guide on how to solder, click here.
  3. NeuTab N7 Pro Battery Replacement: step 3, image 1 of 2 NeuTab N7 Pro Battery Replacement: step 3, image 2 of 2
    • Insert plastic spudger under the battery and slide back and forth, separating the battery from the case.
3 other people completed this guide.
Eric Fiske
430 Reputation
2 Guides authored
USF Tampa, Team 7-1, Cheng Spring 2016 Member of USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 2,134
