NeuTab N7 Pro Camera Replacement
  1. NeuTab N7 Pro Camera Replacement, Camera: step 1, image 1 of 1
    • Power off your device before beginning disassembly
    • Insert plastic opening tool and pry back case away, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Camera Replacement: step 2, image 1 of 1
    • Locate the camera unit and note where it is attached to the motherboard.
    • Use a black nylon spudger to remove the adhesive holding it onto to the motherboard.
    • Metal tools can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device.
  3. NeuTab N7 Pro Camera Replacement: step 3, image 1 of 2 NeuTab N7 Pro Camera Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use a black nylon spudger or tweezers to release the connector holding the camera ribbon cable in place.
    • Carefully pull the ribbon cable out, removing the camera from the motherboard.
Robsander Carrasquero
141 Reputation
1 Guide authored
USF Tampa, Team 7-1, Cheng Spring 2016 Member of USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 318
