Newport e360 Exhalation Flow Sensor Replacement
  1. Newport e360 Exhalation Flow Sensor Replacement, Exhalation Flow Sensor: step 1, image 1 of 1
    • Turn off ventilator before starting this repair.
    • Shut off or disconnect the air and oxygen gas supplies before starting this repair.
  2. Newport e360 Exhalation Flow Sensor Replacement: step 2, image 1 of 1
    • To avoid damaging equipment, always use standard electrostatic discharge (ESD) precautions
    • Put on an ESD wrist strap or ESD gloves
  3. Newport e360 Exhalation Flow Sensor Replacement: step 3, image 1 of 1
    • Open the Front Panel Door on the lower left front of the ventilator to expose Exhalation Valve EXH2105A and Flow Sensor FLS2101P.
  4. Newport e360 Exhalation Flow Sensor Replacement: step 4, image 1 of 1
    • Remove the Exhalation Valve EXH2105A by releasing the retaining latch.
  5. Newport e360 Exhalation Flow Sensor Replacement: step 5, image 1 of 1
    • Disconnect the Flow Sensor Cable CBL2123P from the plastic body of the Flow Sensor FLS2101P by pulling cable straight up. Do not twist.
  6. Newport e360 Exhalation Flow Sensor Replacement: step 6, image 1 of 1
    • With a twisting motion, pull the plastic Flow Sensor FLS2101P away from the outlet of the Exhalation Valve EXH2105A.
2 other people completed this guide.
Lauren Ochoa
165 Reputation
1 Guide authored
Cal Poly, Team S7-G21, Paton Spring 2020 Member of Cal Poly, Team S7-G21, Paton Spring 2020
CPSU-PATON-S20S7G21
3 Members
3 Guides authored
2 Guide Comments
I need this Exhalation Valve EXH2105A part, does anyone have a replacement?
Remigio Rodriguez - Reply
I need this
Cable NEWPORT GR-CBL2123P Flow Meter Parts P/N GR-CBL2123P
Please confirmwd to edisonmanullang@gmail.com
Thanks
Edison Simanullang - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 690
