Newport e360 Oxygen Sensor Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Newport e360 Oxygen Sensor  Replacement, Oxygen Sensor: step 1, image 1 of 1
    • Turn off ventilator before starting this repair.
    • Shut off or disconnect the air and oxygen gas supplies before starting this repair.
  2. Newport e360 Oxygen Sensor  Replacement: step 2, image 1 of 1
    • To avoid damaging equipment, always use standard electrostatic discharge (ESD) precautions
    • Put on an ESD wrist strap or ESD gloves
  3. Newport e360 Oxygen Sensor  Replacement: step 3, image 1 of 1
    • Remove the 2 screws (phillips size 1) securing DOR2112M to the front of the e360 ventilator.
    • Pull back the cover to gain access to the oxygen sensor
  4. Newport e360 Oxygen Sensor  Replacement: step 4, image 1 of 1
    • Remove the Oxygen Sensor cable CBL2109A from the Oxygen Sensor R125P03-002 by unscrewing the connector on the cable
  5. Newport e360 Oxygen Sensor  Replacement: step 5, image 1 of 1
    • Remove the Oxygen Sensor by unscrewing the Oxygen Sensor counterclockwise.
    • If the Oxygen Sensor is installed too tightly to be removed, place a Newport reusable circuit on the oxygen sensor to obtain better friction while unscrewing the Oxygen Sensor.
Rylan Loader
243 Reputation
1 Guide authored
Cal Poly, Team S7-G21, Paton Spring 2020 Member of Cal Poly, Team S7-G21, Paton Spring 2020
CPSU-PATON-S20S7G21
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 576
