Newport e500 Right Side Panel Disassembly
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Newport e500 Right Side Panel Disassembly, Newport e500 Top Cover Disassembly: step 1, image 1 of 1
    • Place device so that the top cover is facing you.
    • Open the top cover.
  2. Newport e500 Right Side Panel Disassembly: step 2, image 1 of 1
    • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
  3. Newport e500 Right Side Panel Disassembly: step 3, image 1 of 1
    • Remove the cover and set aside. Retain hardware for re-assembly.
  4. Newport e500 Right Side Panel Disassembly, Newport e500 Right Side Panel Disassembly: step 4, image 1 of 1
    • Carefully place the GDU on its left side.
  5. Newport e500 Right Side Panel Disassembly: step 5, image 1 of 1
    • Remove the four screws and washers at the top edge of the right side panel.
  6. Newport e500 Right Side Panel Disassembly: step 6, image 1 of 1
    • Remove the two screws and washers from the underside of the right side panel.
  7. Newport e500 Right Side Panel Disassembly: step 7, image 1 of 1
    • Remove the right side panel. Retain hardware for re-assembly.
Jeremy
589 Reputation
6 Guides authored
Cal Poly, Team S7-G16, Paton Spring 2020 Member of Cal Poly, Team S7-G16, Paton Spring 2020
CPSU-PATON-S20S7G16
3 Members
13 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 71
