NexTime Wall Pad Clock Movement Replacement
  1. NexTime Wall Pad Clock Movement Replacement, Clock Movement: step 1, image 1 of 1
    • Place the clock face down.
    • Remove the battery.
  2. NexTime Wall Pad Clock Movement Replacement: step 2, image 1 of 2 NexTime Wall Pad Clock Movement Replacement: step 2, image 2 of 2
    • Turn the brown gear clockwise until both the minute and hour hands align.
  3. NexTime Wall Pad Clock Movement Replacement: step 3, image 1 of 2 NexTime Wall Pad Clock Movement Replacement: step 3, image 2 of 2
    • Use a pair of pliers to pull out the cap.
  4. NexTime Wall Pad Clock Movement Replacement: step 4, image 1 of 2 NexTime Wall Pad Clock Movement Replacement: step 4, image 2 of 2
    • Pull out the minute hand using your fingers.
  5. NexTime Wall Pad Clock Movement Replacement: step 5, image 1 of 2 NexTime Wall Pad Clock Movement Replacement: step 5, image 2 of 2
    • Pull out the hour hand using your fingers.
  6. NexTime Wall Pad Clock Movement Replacement: step 6, image 1 of 3 NexTime Wall Pad Clock Movement Replacement: step 6, image 2 of 3 NexTime Wall Pad Clock Movement Replacement: step 6, image 3 of 3
    • Find the two ridges on the washer.
    • Use a pair of pliers to screw the washer out with a counter clockwise motion.
    • Use your fingers to remove the washer.
  7. NexTime Wall Pad Clock Movement Replacement: step 7, image 1 of 1
    • Take out the clock movement mechanism and replace it.
Leo Santos
145 Reputation
1 Guide authored
1 Guide Comment
what size to by the shaf nexime
john - Reply
Past 24 Hours: 5
Past 7 Days: 11
Past 30 Days: 48
All Time: 2,190
