Nextbook Premium 7SE Battery Replacement
  1. Nextbook Premium 7SE Battery Replacement, Back Cover: step 1, image 1 of 3 Nextbook Premium 7SE Battery Replacement, Back Cover: step 1, image 2 of 3 Nextbook Premium 7SE Battery Replacement, Back Cover: step 1, image 3 of 3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Nextbook Premium 7SE Battery Replacement: step 2, image 1 of 1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Nextbook Premium 7SE Battery Replacement, Battery: step 3, image 1 of 1
    • Remove masking tape from the battery.
  4. Nextbook Premium 7SE Battery Replacement: step 4, image 1 of 3 Nextbook Premium 7SE Battery Replacement: step 4, image 2 of 3 Nextbook Premium 7SE Battery Replacement: step 4, image 3 of 3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Nextbook Premium 7SE Battery Replacement: step 5, image 1 of 3 Nextbook Premium 7SE Battery Replacement: step 5, image 2 of 3 Nextbook Premium 7SE Battery Replacement: step 5, image 3 of 3
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. How To Solder and Desolder Connections
    • Use caution when operating the soldering iron.
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
Walker Karstens
364 Reputation
3 Guides authored
Baylor, Team 4-1, Williams Fall 2016 Member of Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 727
