Nextplay NP109CR Speakers Replacement
  1. Nextplay NP109CR Speakers Replacement, Speakers: step 1, image 1 of 1
    • Turn the device over so it is upside-down.
  2. Nextplay NP109CR Speakers Replacement: step 2, image 1 of 1
    • Unscrew the 4 screws closest to the screen.
  3. Nextplay NP109CR Speakers Replacement: step 3, image 1 of 1
    • Flip over the device so it is right side up.
  4. Nextplay NP109CR Speakers Replacement: step 4, image 1 of 1
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Nextplay NP109CR Speakers Replacement: step 5, image 1 of 1
    • Take off top piece by using slight force and pulling off.
  6. Nextplay NP109CR Speakers Replacement: step 6, image 1 of 1
    • Unscrew the button board with smaller screwdriver.
  7. Nextplay NP109CR Speakers Replacement: step 7, image 1 of 1
    • Lift off the button board.
  8. Nextplay NP109CR Speakers Replacement: step 8, image 1 of 1
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  9. Nextplay NP109CR Speakers Replacement: step 9, image 1 of 1
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  10. Nextplay NP109CR Speakers Replacement: step 10, image 1 of 1
    • Flip the screen and the logic board over to the right side.
  11. Nextplay NP109CR Speakers Replacement: step 11, image 1 of 1
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
Michelle Read
1 Reputation
1 Guide authored
Cal Poly, Team 7-50, Forte Fall 2012 Member of Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 408
