Nexus 10 Front Facing Camera Replacement
  1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: step 1, image 1 of 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: step 1, image 2 of 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: step 1, image 3 of 3
    • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
  2. Nexus 10 Front Facing Camera Replacement: step 2, image 1 of 3 Nexus 10 Front Facing Camera Replacement: step 2, image 2 of 3 Nexus 10 Front Facing Camera Replacement: step 2, image 3 of 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  3. Nexus 10 Front Facing Camera Replacement: step 3, image 1 of 3 Nexus 10 Front Facing Camera Replacement: step 3, image 2 of 3 Nexus 10 Front Facing Camera Replacement: step 3, image 3 of 3
    • Lift latch on front-facing camera connector.
    • Pull the connector toward the top of the device and remove the front-facing camera.
Benjamin Troller
2,218 Reputation
5 Guides authored
Cal Poly, Team 34-18, Maness Spring 2016 Member of Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 612
