Nexus 10 Headphone Jack Replacement
Benjamin Troller
Benjamin Troller and 6 other contributors
Last updated on June 16, 2016
No estimate
Moderate
Better Introduction
  1. Nexus 10 Headphone Jack Replacement, Battery: step 1, image 1 of 3 Nexus 10 Headphone Jack Replacement, Battery: step 1, image 2 of 3 Nexus 10 Headphone Jack Replacement, Battery: step 1, image 3 of 3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 Headphone Jack Replacement: step 2, image 1 of 1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 Headphone Jack Replacement: step 3, image 1 of 3 Nexus 10 Headphone Jack Replacement: step 3, image 2 of 3 Nexus 10 Headphone Jack Replacement: step 3, image 3 of 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  4. Nexus 10 Headphone Jack Replacement: step 4, image 1 of 3 Nexus 10 Headphone Jack Replacement: step 4, image 2 of 3 Nexus 10 Headphone Jack Replacement: step 4, image 3 of 3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
  5. Nexus 10 Headphone Jack Replacement: step 5, image 1 of 1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 Headphone Jack Replacement: step 6, image 1 of 2 Nexus 10 Headphone Jack Replacement: step 6, image 2 of 2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
  7. Nexus 10 Headphone Jack Replacement, Headphone Jack: step 7, image 1 of 1
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 Headphone Jack Replacement: step 8, image 1 of 3 Nexus 10 Headphone Jack Replacement: step 8, image 2 of 3 Nexus 10 Headphone Jack Replacement: step 8, image 3 of 3
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 Headphone Jack Replacement: step 9, image 1 of 3 Nexus 10 Headphone Jack Replacement: step 9, image 2 of 3 Nexus 10 Headphone Jack Replacement: step 9, image 3 of 3
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 Headphone Jack Replacement: step 10, image 1 of 2 Nexus 10 Headphone Jack Replacement: step 10, image 2 of 2
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 Headphone Jack Replacement: step 11, image 1 of 1
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 Headphone Jack Replacement: step 12, image 1 of 2 Nexus 10 Headphone Jack Replacement: step 12, image 2 of 2
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
  13. Nexus 10 Headphone Jack Replacement: step 13, image 1 of 2 Nexus 10 Headphone Jack Replacement: step 13, image 2 of 2
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 Headphone Jack Replacement: step 14, image 1 of 2 Nexus 10 Headphone Jack Replacement: step 14, image 2 of 2
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
Benjamin Troller
2,218 Reputation
5 Guides authored
Cal Poly, Team 34-18, Maness Spring 2016 Member of Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 752
