Nexus 4 Plastic Midframe Replacement
  1. Nexus 4 Plastic Midframe Replacement, Back Cover: step 1, image 1 of 2 Nexus 4 Plastic Midframe Replacement, Back Cover: step 1, image 2 of 2
    Tool used on this step:
    SIM Card Eject Tool
    $2.99
    Buy
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Plastic Midframe Replacement: step 2, image 1 of 1
    T5 Torx Screwdriver
    $5.49
    Buy
  3. Nexus 4 Plastic Midframe Replacement: step 3, image 1 of 3 Nexus 4 Plastic Midframe Replacement: step 3, image 2 of 3 Nexus 4 Plastic Midframe Replacement: step 3, image 3 of 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Plastic Midframe Replacement, Battery: step 4, image 1 of 2 Nexus 4 Plastic Midframe Replacement, Battery: step 4, image 2 of 2
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
  5. Nexus 4 Plastic Midframe Replacement, Battery removal: step 5, image 1 of 2 Nexus 4 Plastic Midframe Replacement, Battery removal: step 5, image 2 of 2
    Plastic Cards
    $2.99
    Buy
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  6. Nexus 4 Plastic Midframe Replacement, Plastic Midframe: step 6, image 1 of 3 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: step 6, image 2 of 3 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: step 6, image 3 of 3
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
7 other people completed this guide.
Kaitlyn Jones
4,964 Reputation
8 Guides authored
Cal Poly, Team 3-32, Amido Winter 2013 Member of Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 20
All Time: 11,226
