Nexus 4 Speaker Replacement
Kaitlyn Jones
Kaitlyn Jones and 5 other contributors
Last updated on January 28, 2016
No estimate
Moderate
Introduction
Go to step 1
This guide will detail how to remove and install the phone's speakers, located at the bottom of the Nexus 4.
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. Nexus 4 Speaker Replacement, Back Cover: step 1, image 1 of 2 Nexus 4 Speaker Replacement, Back Cover: step 1, image 2 of 2
    Tool used on this step:
    SIM Card Eject Tool
    $2.99
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Speaker Replacement: step 2, image 1 of 1
    T5 Torx Screwdriver
    $5.49
  3. Nexus 4 Speaker Replacement: step 3, image 1 of 3 Nexus 4 Speaker Replacement: step 3, image 2 of 3 Nexus 4 Speaker Replacement: step 3, image 3 of 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Speaker Replacement, Battery: step 4, image 1 of 2 Nexus 4 Speaker Replacement, Battery: step 4, image 2 of 2
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
  5. Nexus 4 Speaker Replacement, Battery removal: step 5, image 1 of 2 Nexus 4 Speaker Replacement, Battery removal: step 5, image 2 of 2
    Plastic Cards
    $2.99
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  6. Nexus 4 Speaker Replacement, Speaker: step 6, image 1 of 2 Nexus 4 Speaker Replacement, Speaker: step 6, image 2 of 2
    • Remove the two 4.8 mm screws that hold the speaker enclosure together using the Phillips 00 screwdriver.
  7. Nexus 4 Speaker Replacement: step 7, image 1 of 2 Nexus 4 Speaker Replacement: step 7, image 2 of 2
    • Gently pry the speaker up and away from the back of the phone using a plastic opening tool, and lift it out of the phone.
10 other people completed this guide.
Kaitlyn Jones
4,964 Reputation
8 Guides authored
Cal Poly, Team 3-32, Amido Winter 2013 Member of Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 13,364
