Nexus 5 SIM Card Replacement
  1. Nexus 5 SIM Card Replacement, SIM Card: step 1, image 1 of 2 Nexus 5 SIM Card Replacement, SIM Card: step 1, image 2 of 2
    • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
    • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
    • Push the tool into the hole until you see the card pop out.
  2. Nexus 5 SIM Card Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
    • Make sure the chip is facing the rear of the phone when reinserting the SIM card.
2 other people completed this guide.
Kyle Libby
1,006 Reputation
7 Guides authored
Cal Poly, Team 7-23, Regan Spring 2014 Member of Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
4 Members
19 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 17
All Time: 4,332
