Nexus 5X Motherboard Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Nexus 5X Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 1
    • Use an iOpener to loosen the adhesive beneath the rear facing camera. Place the iOpener across the top part of the phone for about 30 seconds.
  2. Nexus 5X Motherboard Assembly Replacement: step 2, image 1 of 2 Nexus 5X Motherboard Assembly Replacement: step 2, image 2 of 2
    • Apply the flat end of a spudger to the left side of the rear facing camera and carefully lever it up. Make sure all of the adhesive underneath is loosened.
  3. Nexus 5X Motherboard Assembly Replacement: step 3, image 1 of 2 Nexus 5X Motherboard Assembly Replacement: step 3, image 2 of 2
    • Use the flat end of a spudger to pry up the display flex connector.
  4. Nexus 5X Motherboard Assembly Replacement: step 4, image 1 of 3 Nexus 5X Motherboard Assembly Replacement: step 4, image 2 of 3 Nexus 5X Motherboard Assembly Replacement: step 4, image 3 of 3
    • Grip the lower part of the motherboard with your fingers and carefully lift it upwards.
    • There's a small plastic clip next to the rear-facing camera that holds the motherboard in place.
    • Gently pull the motherboard towards the bottom edge to free it from the plastic clip next to the rear-facing camera.
    • Carefully lift the motherboard out of the frame.
    • Be careful—the two cameras are still connected to the board.
Dominik Schnabelrauch
211,758 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,077 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 54
