Nexus 7 Display Assembly Replacement
Video Overview
  1. Nexus 7 Display Assembly Replacement, Rear Panel: step 1, image 1 of 1
    • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
    • Do not use excessive force while prying the clips. They can be easily broken.
  2. Nexus 7 Display Assembly Replacement: step 2, image 1 of 2 Nexus 7 Display Assembly Replacement: step 2, image 2 of 2
    • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
  3. Nexus 7 Display Assembly Replacement: step 3, image 1 of 3 Nexus 7 Display Assembly Replacement: step 3, image 2 of 3 Nexus 7 Display Assembly Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
  4. Nexus 7 Display Assembly Replacement: step 4, image 1 of 3 Nexus 7 Display Assembly Replacement: step 4, image 2 of 3 Nexus 7 Display Assembly Replacement: step 4, image 3 of 3
    • Pry up the rear panel along the left edge using the method described in previous steps.
  5. Nexus 7 Display Assembly Replacement: step 5, image 1 of 2 Nexus 7 Display Assembly Replacement: step 5, image 2 of 2
    • Gently lift and remove the rear panel up off the front panel assembly.
  6. Nexus 7 Display Assembly Replacement, Battery Cable: step 6, image 1 of 2 Nexus 7 Display Assembly Replacement, Battery Cable: step 6, image 2 of 2
    • Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
  7. Nexus 7 Display Assembly Replacement, Display Assembly: step 7, image 1 of 2 Nexus 7 Display Assembly Replacement, Display Assembly: step 7, image 2 of 2
    • Peel the upper piece of black adhesive tape completely up off the Nexus 7.
    • Similarly, peel the lower piece of black adhesive tape, but only as far as the copper strip.
    • It is helpful to fold this piece of tape back on itself to keep it out of the way.
    • Whilst pulling the tape, be sure that the metal shield does not lift up. Hold the shield in place, and if it lifts up, re-seat it in the spring clips around the perimeter of the shielded area.
  8. Nexus 7 Display Assembly Replacement: step 8, image 1 of 1
    • Use the flat end of a spudger to pry the display data cable straight up off its socket on the motherboard.
  9. Nexus 7 Display Assembly Replacement: step 9, image 1 of 3 Nexus 7 Display Assembly Replacement: step 9, image 2 of 3 Nexus 7 Display Assembly Replacement: step 9, image 3 of 3
    • Use the flat end of a spudger to carefully flip up the retaining flaps on the digitizer ribbon cable ZIF sockets.
    • Make sure you are flipping up the white retaining flaps, not the black sockets themselves.
    • Use the tip of a spudger to pull the digitizer ribbon cable straight out of its socket.
  10. Nexus 7 Display Assembly Replacement: step 10, image 1 of 2 Nexus 7 Display Assembly Replacement: step 10, image 2 of 2
    • Remove the following screws securing the display assembly to the metal frame:
    • Thirteen 3.2 mm silver Phillips screws
    • Two 4.25 mm black Phillips screws
    • In 3G models, the two top-center Phillips screws are slightly lower and on top of the motherboard.
    • Note that the assembly for the non-3G model will NOT fit the 3G model. When looking for the 3G assembly, look for model 'ME370TG', and note that in pictures of the 3G verison the top 2 phillips screw holes are slightly lower than the upper right and left ones.
  11. Nexus 7 Display Assembly Replacement: step 11, image 1 of 1
    • The display assembly is held in place by a large amount of adhesive on the underside of the large copper ESD shield. In the next few steps, you will be using a plastic spudger to release this adhesive.
    • Work carefully and slowly, making sure to not break the I/O data cable.
  12. Nexus 7 Display Assembly Replacement: step 12, image 1 of 3 Nexus 7 Display Assembly Replacement: step 12, image 2 of 3 Nexus 7 Display Assembly Replacement: step 12, image 3 of 3
    • Insert a plastic spudger on the left side of the Nexus 7, near the bottom of the battery.
    • Only insert the spudger enough to free the adhesive (about halfway across the Nexus 7)—if you go any farther, you may damage the LCD cable.
    • Slide the spudger toward the top of the Nexus 7, releasing the adhesive as you go.
  13. Nexus 7 Display Assembly Replacement: step 13, image 1 of 1
    • Carefully rotate the metal frame away from the display assembly, minding any cables that may get caught.
    • You may need to apply heat to the display assembly before lifting it away from the device.
    • Display assembly remains.
228 other people completed this guide.
Brett Hartt
131,269 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,817 Guides authored
43 Guide Comments
great but where can i get nexus 7 digitizer, in stock reasonable price in uk please?
Rupert K - Reply
eBay is a good source. I paid £14 for mine and it came with tools.
Robert Leather -
I don't feel that this guide is complete, how do you separate the display from the frame?
Chris - Reply
That's because this guide is for the "Display Assembly". I just tried to remove the LCD itself, extremely difficult. I didn't succeed. Now looking for a whole assembly
Jeremy Cooper -
I've managed to do it using a heat gun. Be careful not to apply to much heat as I warped the frame slightly in one place. Use a prying tool from the top rather than trying to push from the back as the glue is quite tough and peeling it away is easier. You need to reapply heat as you work, it then comes out quite easily. I repurposed the glue strips from the old screen, however taking out bits of glass was a bit tough. The new display fits neatly after that.
Nadim M -
Past 24 Hours: 16
Past 7 Days: 130
Past 30 Days: 663
All Time: 308,694
