Nexus 7 Power & Volume Button Cable Replacement
  1. Nexus 7 Power & Volume Button Cable Replacement, Rear Panel: step 1, image 1 of 1
    • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
    • Do not use excessive force while prying the clips. They can be easily broken.
  2. Nexus 7 Power & Volume Button Cable Replacement: step 2, image 1 of 2 Nexus 7 Power & Volume Button Cable Replacement: step 2, image 2 of 2
    • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
  3. Nexus 7 Power & Volume Button Cable Replacement: step 3, image 1 of 3 Nexus 7 Power & Volume Button Cable Replacement: step 3, image 2 of 3 Nexus 7 Power & Volume Button Cable Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
  4. Nexus 7 Power & Volume Button Cable Replacement: step 4, image 1 of 3 Nexus 7 Power & Volume Button Cable Replacement: step 4, image 2 of 3 Nexus 7 Power & Volume Button Cable Replacement: step 4, image 3 of 3
    • Pry up the rear panel along the left edge using the method described in previous steps.
  5. Nexus 7 Power & Volume Button Cable Replacement: step 5, image 1 of 2 Nexus 7 Power & Volume Button Cable Replacement: step 5, image 2 of 2
    • Gently lift and remove the rear panel up off the front panel assembly.
  6. Nexus 7 Power & Volume Button Cable Replacement, Battery Cable: step 6, image 1 of 2 Nexus 7 Power & Volume Button Cable Replacement, Battery Cable: step 6, image 2 of 2
    • Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
  7. Nexus 7 Power & Volume Button Cable Replacement, Power & Volume ZIF Connector: step 7, image 1 of 1
    • Peel back the label covering the power and volume button ZIF connector.
  8. Nexus 7 Power & Volume Button Cable Replacement: step 8, image 1 of 2 Nexus 7 Power & Volume Button Cable Replacement: step 8, image 2 of 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the power and volume button ribbon cable ZIF socket.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the power and volume button ribbon cable straight out of its socket.
  9. Nexus 7 Power & Volume Button Cable Replacement, Power & Volume Button Cable: step 9, image 1 of 2 Nexus 7 Power & Volume Button Cable Replacement, Power & Volume Button Cable: step 9, image 2 of 2
    • Insert the flat end of a spudger between the power and volume button cable and the metal frame.
    • Carefully slide the spudger along the length of the ribbon cable, releasing the buttons.
    • T
  10. Nexus 7 Power & Volume Button Cable Replacement: step 10, image 1 of 1
    • Remove the power and volume button ribbon cable from the Nexus 7.
4 other people completed this guide.
7 Guide Comments
Hi All,
I've been to Orlando/FL this Sept/October and I bought 2 ASUS NEXUS 7 Tablets.
The first one was opened and used there, in Orlando. The second one, is a gift for my wife, and we had just unopened the box (yes, december/11/2012) and for our surprise the device simply do not turned on. I did a search on Internet, and I have opened the device. As we have two devices, I could compare and I noticed that it has a Missing "small flat cable", the one with the function of the buttons (power and volume).
I took a picture of both devices, if you tell me how, I can send you the pictures.
Where can I "buy" this small cable?
Thanks for your support.
Marcos Guireli - Reply
Nice, but can u show how to do it with 2013 nexus 7? Pls, i need to replace my n7 buttons.
sotyka94 - Reply
what's the problem of your nexus 7 (2013)?
leopay -
The volume buttons on my Nexus 7 (2013) don't work. Is this procedure applicable to the 2013 version and do you think it will solve the problem?
Carl Bezanson - Reply
Carl, Its the same fix as the Power& Volume Button Cable in our free guide u downloaded
Mike Patrick - Reply
Past 24 Hours: 7
Past 7 Days: 43
Past 30 Days: 94
All Time: 32,103
