Nexus 9 Antenna Board Replacement
Geoff Wacker
Geoff Wacker and 3 other contributors
Last updated on May 7, 2024
No estimate
Moderate
Introduction
Go to step 1
Use this guide to replace the antenna board on your Nexus 9.
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. Nexus 9 Antenna Board Replacement, Rear Case: step 1, image 1 of 3 Nexus 9 Antenna Board Replacement, Rear Case: step 1, image 2 of 3 Nexus 9 Antenna Board Replacement, Rear Case: step 1, image 3 of 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Antenna Board Replacement, Antenna Board: step 2, image 1 of 2 Nexus 9 Antenna Board Replacement, Antenna Board: step 2, image 2 of 2
    • This step is not necessary if you have already removed the battery.
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Antenna Board Replacement: step 3, image 1 of 1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  4. Nexus 9 Antenna Board Replacement: step 4, image 1 of 1
    Tool used on this step:
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
Geoff Wacker
91,064 Reputation
89 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,421
